a couple questions about meerkat 50cc
does anybody know the ngk sparkplug number for this quad
and also what is the spark gap on this quad
has anybody had a problem with the gas tank neck cracking ive bought 2 gas tanks and both did it
I appreciate your time!
fink,
I can't tell you what the gap should bem but my tank neck cracked as well. I fixed mine so that it would never do it again. I emptied the tank and cleaned around the inside of the neck. Then I mixed up some JB Weld and coated the entire inside of the neck with it. Gives the neck another layer that will not crack. Never had another problem again after that. You can get JB Weld in tubes at Lowes/Home Depot or your local hardware store. It's good stuff.
Thank you very much for the correct gap billl
hey godilove2ride did you put that jb weld on the inside or around the outside
and if you put it in the inside you never had problems with the gas dissolving it?
I coated the entire inside of the neck, and gas will not dissolve the JB Weld once it's cured. I used the JB Quick Weld that cures in a few hours.
sweet thank you very much i tryed the jb weld fix and it worked like a champ i (and my wallet )appreciate the advice[img]i/expressions/face-icon-small-happy.gif[/img]
toonces
Oct 16, 2019 12:11 PM
