Lt 80 head shaved Jetting ??? Where do you get jets???
Old Apr 24, 2007 | 02:16 PM
Ddog87's Avatar
Default Lt 80 head shaved Jetting ???
Had the head shaved 30 thou, what jets should I go to now?? Do I need to run race fuel it this now?? Clutch mod is next along with chain.
Old Apr 24, 2007 | 05:41 PM
LT80's Avatar
LT80 Expert
The stock jetting is fine. Usually a lil fat. If the plug is dark, you can go down to a 90 main jet.
Pump gas is fine. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 24, 2007 | 06:11 PM
Ddog87's Avatar
That's what I thought, the local "engine builder" said I will need to step up to a 110 or 120 and that I will HAVE to run race gas. Were is a good place to buy jets?? THanks
Old Apr 27, 2007 | 08:00 PM
Ddog87's Avatar
Default Lt 80 head shaved Jetting ??? Where do you get jets???
Were do you get jets??
Old Apr 28, 2007 | 11:17 AM
LT80's Avatar
LT80 Expert
I get mine at a Marshall distributor.
Most any dealership/shop should be able to get em.
Not running right? What's it doing?
Old Apr 28, 2007 | 12:22 PM
holtzer1's Avatar
high compression does not require jet changes
you need to do a compression check to know if you need race gas or not
compression psi over 145 needs race gas.
Old Apr 29, 2007 | 01:39 PM
Ddog87's Avatar
Running fine just needed to know where to get jets to jet down to a 90
pgamboa
Dec 24, 2023 11:52 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Bigtwin700
Sep 9, 2015 09:32 AM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 5, 2015 08:44 PM
