clutch help on sunl 110st
Old May 20, 2007 | 07:00 PM
swdockter's Avatar
Default clutch help on sunl 110st
clutch just slips. kid got hung up in mud hold and probably burned it up. I need a place to start. Pulled the left side cover off and looks to be stator. Is the clutch on the other side...assuming yes....do I first drain the oil? Is there any adjustment ?
thanks in advance....btw, no manual on the web that I can find.
Old May 20, 2007 | 09:31 PM
RacewayATV's Avatar
Yes the clutch is on the right hand side of the motor. Take the center cover off (meaning there may be a cover in the center on the engine that says Sunl.) When this is off you should see a 10mm nut on a threaded rod coming from the engine. Loosen this little nut and try to turn the threaded rod with a screw driver. (There is a cut in the rod that a smaller screw driver will fit in.) Try to adjusts this a little bit and see if she grabs better.
Kids ATV Raceway ATV
Old May 20, 2007 | 09:51 PM
swdockter's Avatar
thanks buddy. i'll try that. I did take the cover off but had no clue what that was or what to do.
Old May 23, 2007 | 10:46 PM
swdockter's Avatar
Raceway,
I adjusted the clutch. started with about 2 turns to the left. Nothing so i went a couple more turns left. Then it would not shift into gear. Then tried to go back to the right and now the <u>slotted shaft will not turn in either direction</u>.
Now what? Time to drain oil? By the way was a 13mm nut on this Sunl 110.
thanks for your help....
Scott
Old Jun 17, 2007 | 12:24 AM
swdockter's Avatar
Well, i tried to take the clutch apart. Could not get the screws out that hold jn the clutch. Just bought a impact screwdriver and going to try that.
Do I take the 4 inside or 4 outside screws out?
Old Jun 17, 2007 | 12:35 PM
itch's Avatar
pretty nice of that raceway guy to get you started ,but where is he now? seems as tho he has dropped the ball bigtime, i see he is still answering post on other subjects.
maybe start a new post directed toward him with your questions will get his attention
Old Jun 20, 2007 | 01:46 AM
thenewshooter's Avatar
I am having the same problem with my sons Kazuma 110. Although I was able to adjust the clutch for more grip. Not enough for me to ride it though[img]i/expressions/face-icon-small-frown.gif[/img]. So I also goin have to replace clutch. I have never replaced a clutch before so if/when you fix yours could you leave some pointers?
Old Jun 21, 2007 | 10:42 PM
RacewayATV's Avatar
swdockter sorry about not answering the post. Most times if I get into a post I get an email when there is a reply! Did not happen on this one but I just was reading around tonight but anyway give me a call and I can try to help you out way to much info to post!
John.
Old Jun 24, 2007 | 05:32 PM
swdockter's Avatar
well, i have been pretty busy with business. Got back to pulling the screws oit of the clutch. The inner 4 screws reveal the circular nut with 4 keyways. Obviously, I now need that special socket.
Anybody know where to find one of these?
Old Jun 24, 2007 | 06:35 PM
smb05's Avatar
Here you go. Oil Filter & Clutch Hub Spanner For Honda I would call first to make sure it fits your application.
Good Luck.
SB.
