atv allignment? 200cc quad pulls to the left..
are you talking about the slime that goes around the inside of the tire, where it meets the rim? I might try that out.. be sure to correct me if i'm wrong though.
The slime is actually a bottle of tire sealant you put into the tire and it will plug little holes just like a can of fix-a-flat but the green slime is much better.
If the tire is leaking around the bead *edge of tire and rim* then you would need to remove the tire and apply a little tire glue to the bead. I do not know the exact name but it helps to bead tires not sealing well.
<div class="FTQUOTE"><begin quote>Originally posted by: nrmarine607
But a tiny bit off topic.. (kinda) Is changing my front wheels around going to cause a problem in the alignment or the wheels themselves? I have the air caps facing in.. So the front end sits just a tish wider. I could always change it back, I just dont know if those little nuts on those wheels can handle them like that. Any opinions?
ALSO, I've got one rear tire that keeps losing pressure. I fill it up every other day before I go out and ride.. Any way that yall know of to fix this?</end quote></div>
Try changing the valve. I had a tire that kept losing pressure ang I replaced the valve and haven't had a problem since.
Frisky2050
Apr 9, 2020 11:19 AM
