Giovanni 50cc Quad Hard starting
Old Jan 27, 2008 | 06:15 PM
jmiller67's Avatar
Default Giovanni 50cc Quad Hard starting
I can seem to get the unit to start. The only way is to shoot some gas down the carb. Anyone else having issues
Old Jan 27, 2008 | 06:18 PM
onebigzj's Avatar
is it new, old. adjust carb air fuel mix screw. more info please
Old Jan 27, 2008 | 06:31 PM
jmiller67's Avatar
Brand new. Once the unit is running it is ok and idles and runs ok. Is the air fule the screw with the spring or is that just idle?
Old Jan 27, 2008 | 06:48 PM
onebigzj's Avatar
its a little screw no spring. thers only 2 screws
1st- with spring is idle
2nd fuel air mix
when looking at carb you will only see the slot where screwdriver goes. turn in (clock wise) slowly and when it seats turn out ( counter clock wise) 2 full turns. be easy when turning in dont I repeat donot turn tight just to seat it. mine did the same thing after alittle. ran like crap untill it warmed up. this will help. also you are using the choke right!
Old Jan 27, 2008 | 06:54 PM
jmiller67's Avatar
I must be a real dumb A_ _! Where is the choke. Not like the honda's we have.
Old Jan 27, 2008 | 07:01 PM
onebigzj's Avatar
mine is a little chrome rod on the carb. mine sticks out twords the left side sittinging on it. swings up for choke and down for off
Old Jan 27, 2008 | 07:17 PM
jmiller67's Avatar
This is great it was totally hidden. Now I think it may run. Thank you very much for your advice.
Old Jan 27, 2008 | 07:18 PM
onebigzj's Avatar
no problem let me know
Old Jan 27, 2008 | 08:12 PM
onebigzj's Avatar
did that work????
Old Jan 27, 2008 | 08:21 PM
jmiller67's Avatar
Just in from the garage. It is -25 in Calgary today and it worked. Again thank you very much for the advise. Once I receive the coil for the ZMC 200r for my other son I might email you again.
Once again thank you.
