predator 50
Old Apr 15, 2008 | 06:21 PM
SRD93PGT's Avatar
Default predator 50
If you look at the right side of the machine (Right side if sitting on it) you will see a group of wires wrapped together coming off the block follow them up right under the steering stem near the gas tank. There will be a white plug that holds three wires which are your 12v supply for lights, and there will be two other wires a Black with Red stripe and White with Blue stripe. You can also check the wires right at the CDI box which is under the right fender on the frame. The wires are the same color there. For the coil not showing an resistence that might be the problem but check everything so you don't waste money or time.
Hopefuly this helps if you need more assistence let me know.
Shawn
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
