Chinese ATV Problem
Old May 10, 2008 | 11:36 PM
Flanman5's Avatar
Default Chinese ATV Problem
The solenoid on the back of my sons quad just clicks and the starter will not engage. I have charged the battery and still the same problem.
What could it be?
Thanks
Old May 10, 2008 | 11:57 PM
outofline's Avatar
You can jumper across the two main power terminals on the solenoid from the battery to the starter and if it turns over then it's most likely the solenoid! If it still does the same it's looking like a bad starter!
Old May 12, 2008 | 06:11 AM
fugley's Avatar
I've ran into that problem myself from time to time, check to make sure you have a good ground,, the painted surfaces on the frame and engine case are not adequate enough to give you a good ground.
I used a bit of sandpaper to make sure the mating surfaces have metal to metal contact. not epoxy paint to powder coating.
Firefighter400
Oct 8, 2022 06:38 PM
Frisky2050
Apr 9, 2020 11:19 AM
greg74
Sep 10, 2019 03:03 PM
Waddell4436
Technical and How-To Articles
Jul 19, 2015 04:22 PM
Unzzy66
Jul 11, 2015 10:01 PM
