50cc Action USA Quad
Old May 13, 2008 | 11:57 AM
mcmoose's Avatar
Default 50cc Action USA Quad
I can get this quad to fire. It has always been a really tough starting quad and know it won't start at all anymore. I cleaned out the carb and checked if it has spark (it does) but it just won't start. I am at a loss here and don't know what to do. Does any one know where I should have the idle screw position? What else do I check for or do? Plus you can only kick it over so many times before you want to throw the thing (no electric start)
Old May 13, 2008 | 01:31 PM
chineseatvmechanic's Avatar
on a two stroke engine you only need 3 things to make it run. 1. ignition 2. fuel
3. compression. saying that and you already stated you had ignition, spray a little starting fluid in the carb, if it starts then it may be a fuel system failure, if it doesn't start ( lack of compression) then you know it time for new piston and rings.
Old May 13, 2008 | 06:52 PM
mcmoose's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: chineseatvmechanic
3. compression. saying that and you already stated you had ignition, spray a little starting fluid in the carb, if it starts then it may be a fuel system failure, if it doesn't start ( lack of compression) then you know it time for new piston and rings.</end quote></div>
Thanks for replying chineseatvmechanic. Yeah i just tried spraying a little starting fluid in the carb to no success. It did not start so I guess its time for an overhaul. Do you know what the compression is suppose to be as I will check the compression tomorrow before i attempt the overhaul. Is it a pretty easy job to do (i have never done this type of thing before or should I take it somewhere to get done?
Ramman1
Aug 11, 2022 01:53 PM
Frisky2050
Apr 9, 2020 11:19 AM
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
ManuelCarrillo3
Where to Ride
Jul 27, 2015 07:53 PM
Captjay
Jul 23, 2015 12:33 PM
