Need help With my sons Mini
Old May 31, 2008 | 03:06 AM
mavrick674's Avatar
Default Need help With my sons Mini
OK This will be boys who know the deep secrets of these mini quads!
Eton 90r 2stroke
Everything installed:
Hetricks -Bkit with everything that is included
-52mm port & polished cyl.
-Tether kill
The Problem
Son was racing at Lorretta Lynn's GNCC and obviously went thru some mud/water and also he said, had it roll over 1-2 times in the woods. ran 2.5laps and then started sputtering and then slowed down and let out a big puff of white smoke and then died and wouldn't restart. after getting it home I cleaned up the carb/jets/ports full clean job, no dirt in reed cage area. started right up but wouldn't rev strong past about 3/4 to full throttle sitting in neutral or under load. it revs then cuts out quickly then back into rev. almost like a soft rev limiter.
Here is a list of all I have tried
checked comp- 90-95 with carbon fiber reeds, 115 with fiberglass reeds
honed cylinder to put cross hatch back in it
cleaned carb/ports/internal parts 3 times & Air filter
rejetted up and down
changed out with new stator & coil
removed Hetrick spark box used just Stock CDI
removed Stock CDI used just Hetrick box
checked with inline spark test that you hold on outside of plug wire- checked at all different rev areas
cleaned and regreased elec connections
checked kill switches
bypassed kill switches
bypassed all electrical from stock wiring harness that i knew of
ran extra grounds to coil and engine
Sprayed carb cleaner around seals,cyl., carb/intake, no rev up's.
checked float to see if running out of fuel
Is there a bank angle sensor in these that maybe was tripped and has not reset?
I am pulling my hair out!!! Please help.
Thank you!
Old May 31, 2008 | 10:31 AM
LT80's Avatar
LT80 Expert
What's Rich say?
Old May 31, 2008 | 11:03 AM
mavrick674's Avatar
everything I did. I went above and beyond what he has said to do
Can't get ahold of him today and he is so busy thru the week that I can barely talk to him I really need to get this thing going we are missing Kentucky race today because of it and missed the Ohio one 3 weeks ago!
Old Jun 1, 2008 | 11:55 AM
LT80's Avatar
LT80 Expert
Ya know anyone with a carb to try?
Fuel delivery or electrical...but what eh..[img]i/expressions/face-icon-small-sad.gif[/img]
Whitelx1
Oct 2, 2015 10:55 PM
2many2ride
Sep 27, 2015 04:35 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
