LT80 noise
Old Sep 25, 2010 | 06:57 PM
jtcasper's Avatar
Default LT80 noise
Just got a new top end on my 2000 LT80 and plugged the oil pump, which had been leaking. Prior to this, and after, there is a noise sounds like it's coming from the front clutch .. the noise sounds like a few marbles rolling around. Anyway, I serviced the front clutch and replaced the rollers, oil seal and o-ring. Same noise. This noise happens at idle or while in motion. I've seen a few other posts regarding similar issues, but no pattern of what this could be. I know what it ISN'T. The rollers are brand new ... suggestions?
Thanks!!!
Tim
Old Sep 26, 2010 | 07:55 AM
LT80's Avatar
LT80 Expert
I'm guessing that your hearing the main bearings. Maybe the leaking pump didn't get enough oil in.
Old Sep 26, 2010 | 08:49 PM
jtcasper's Avatar
Thanks for the response (I think) !! That sounds like a job .. what is the risk of running it as is, other than some irritating noise?
Old Sep 27, 2010 | 07:38 AM
LT80's Avatar
LT80 Expert
I'd run it.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
