YF60 tri zinger 60. Ccompression and engine specs
Old Nov 17, 2010 | 03:31 PM
fastline's Avatar
Default YF60 tri zinger 60. Ccompression and engine specs
I have an older YF60 that I probably need to take a look at before my next son takes it over. I was looking for any comp ratio or pumping/testing compression specs as well as bore and stroke measurements. I need to see of the bore will work with a new piston or if I will have to bore. I have a PW50 cylinder that is identical that I could bore to a stock piston as well.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
RedRancher
Jul 10, 2015 06:36 PM
