e-Ton viper 150 not starting up - at all! Help please!!
the jets allow the right air fuel mixture into the engine the one you took out it sounds like was your run jet but the idle jet is most commen to get plugged because of its size once you get it cleaned out get it started see how it runs then turn the screw in if its to low and not wanting to idle or if its idling to high turn out
put the coil wire on the spark plug, ground the spark plug up against the jug/cylinder/head. hold it there and crank the engine. this will ground the plug and should show you a spark. i never trusted a tester..
#16
#17
#19
The gas is fresh. It'll be the second time I flushed the gas..
This is getting gas.
The choke works.
But, I found the other jet. :P
It was the big piece that was in the bowl!
I didn't clean that before. I couldn't see daylight.
So it's still soaking.. I'm sure the carb cleaner is gone. Evaporated.
But will that cause it not to work? Becuase the spark was getting gas!
The choke works.
