LT80 new piston & carb rebuild wont start.
Old Apr 25, 2011 | 08:08 PM
jcmets1's Avatar
Default LT80 new piston & carb rebuild wont start.
I have a 1989 LT80 had some scoring and low compression so had the jug honed and bought a new wiesco piston and rings (installed arrow to the exhaust). cleaned the carb out real well and installed a rebuild (new jets, float valve and seat, needle valve, and gaskets) My problem now is the thing wont start. I have great spark and compression 120psi. Plug is getting wet when I crank it over but the thing wont start. About the only thing I have not checked yet is the reeds can this be a problem with starting I had heard that if they are bad the engine will still run just not very well.....
Help please this thing is driving me crazy.
Old Apr 25, 2011 | 08:29 PM
atvkiller's Avatar
how wet is your spark plug getting the motor might be flooding out cause of to much gas somthing might not be set right in carb had the same thing when i cleaned the carbs out on my snowmobile this winter after it sat for 5 years
Old Apr 26, 2011 | 08:39 AM
LT80's Avatar
LT80 Expert
I'm wondering if ful has flooded the bottom end.
Apply full throttle and try to start it.
Old Apr 26, 2011 | 11:12 AM
jcmets1's Avatar
Pulled the reeds out and the right side was broken in half replaced it and she fired right up........
Old Apr 26, 2011 | 07:58 PM
LT80's Avatar
LT80 Expert
Glad you got it going.
kelleycully
Sep 15, 2016 02:57 AM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
Wnthunting
Jul 9, 2015 03:02 PM
yambam13
Jul 4, 2015 01:49 PM
