Konker 70cc will not start
Old Dec 16, 2011 | 11:51 PM
Clarky's Avatar
Default Konker 70cc will not start
Konker 70cc will not start. Have fuel, compression, and spark but timing seems off. Is there a way I can test the timing on the stator? Or any other suggestions. Thanks
Old Dec 17, 2011 | 10:12 PM
LynnEdwards's Avatar
Electrical Expert
I am not familar with your quad at all.
On a lot of quads there is a timing access plug that can be removed above the flywheel which allows you to shine a timing light in to check the ignition timing. [Often new owners try to add oil through this access hole, which of course just runs out the bottom of the side cover...].
You could try checking the timing that way, but remember that the ignition timing is mechanically fixed and not adjustable. So a failure here would be rare, but not impossible. Such rare failures would include:
1) A sheared keyway on the flywheel (altering the relationship between the crankshaft position and the timing/trigger pickup coil in the stator).
2) A defective CDI which could be randomly firing on its own without the trigger signal, or the timing advance with speed circuitry isn't operating right inside the CDI.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Rtgjje5
Jun 16, 2015 08:23 AM
Berjr
Jun 15, 2015 04:41 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
