Trouble starting
Old Feb 20, 2012 | 02:30 PM
bbogdon's Avatar
Default Trouble starting
My son rode his Wildfire WF-90 today for approx 2 hours with no problems. After we returned home and attempted to start it, it would not turn over. It was cranking without any problems but would not turn over completely to start idling. Nothing appears out of order, gas is fresh, air cleaner is not clogged or dirty, battery is new as well as the starter. Any suggestions?
Old Feb 20, 2012 | 03:58 PM
LT80's Avatar
LT80 Expert
2 stroke?
Old Feb 20, 2012 | 07:54 PM
Jaster94's Avatar
check for spark. you didn't mention that. pull the plug out, reconnect the plug wire, ground the spark plug to the jug, crank it. see spark? if no spark, start looking at the safety interlocks. brake switches, tether kill switches, handlebar kill switches. etc.....
Old Feb 20, 2012 | 11:15 PM
bbogdon's Avatar
This is a 4 stroke engine. I was thinking that it may be the plug but wondered why after riding it for 2 hours with no problems why it would suddenly not start
Old Feb 21, 2012 | 07:23 AM
Jaster94's Avatar
several things can go wrong in between rides and during rides. connections can become loose due to jarring the chassis, excessive vibrations, lack of a good quality control program back at the factory or at the local dealer, etc...it can happen to a lot of different machines. wiring failures are a leading cause of a no spark condition. inspect the plug, make sure the ceramic part ain't broken/cracked. test it as specified earlier. if it fails, replace it. NGK makes a good one. your local auto parts store may be able to cross reference from the factory plug. then check your wiring harness and all of the connections/terminals that you can find. make sure they're tight.
Old Feb 21, 2012 | 08:55 AM
LT80's Avatar
LT80 Expert
You da man Jaster.
I agree, check all connections. Maybe the plug wire came loose.
I see MyWifesQuad uses Autolite plugs.
Old Feb 21, 2012 | 09:51 PM
Jaster94's Avatar
Originally Posted by LT80
You da man Jaster.
OH NO!!!!!!! by all means, i've learned from you, MWQ, LYNNEDWARDS, OPT, and many others! i learn and read a lot on the forum. everyone has taught me a lot. i hope i didn't leave anyone out of the kudos comment. . but be aware, i have learned from a lot of folks on here. everyone!
tycobb
ATC 3-Wheelers
Oct 23, 2015 07:37 PM
Mattius
Jul 11, 2015 10:44 PM
merryman
Jun 15, 2015 02:36 AM
1000gade
May 27, 2015 12:37 PM
atving
Nov 17, 1999 09:24 PM
