e-Ton Viper 150 engine repair - crankcase o-ring?
Old Apr 15, 2012 | 10:19 PM
rowebil's Avatar
Originally Posted by Jaster94
it's a centrifugal clutch, i don't think the oil hurt it. probably just the belt was just slipping a tad bit. i don't think you have anything to worry about on your belt drive assembly. just get the crankcase seals replaced and you're ready to rock n roll. car clutch is different. so yeah, you're quad is ok.
That's what I thought but wasn't sure. Awesome so I feel better now that I don't need to buy a new clutch.
Belt looks fairly new. Not worn at all.
Old Apr 20, 2012 | 03:01 PM
Jaster94's Avatar
if you decide to check it out while running and the cover off, obviously stay clear of the moving parts.
Polaris Sportsman CVT clutch - YouTube
Old May 19, 2013 | 12:59 PM
rowebil's Avatar
So, I literally just got time to do the four wheeler engine rebuild and it's done... It took just a few weeks, really wasn't working on it continuously.
However, I replaced a few of the head gaskets and the crankcase plate o-ring, and the ring that is in the middle of the crankcase plate. So, I literally didn't need to pull the engine apart to push the plate out. They have screw holes that you put a screw in and it pulls off... just realized that after looking at it for a while lol.
Oh well, this engine got a fresh rebuild and everything now.
So, there is still a leak in the crankcase plate... the o-ring looks fine. What do you think I should do to fix it? Maybe fill the o-ring area in with PVC cement, and then let it dry and put the o-ring back in? It seems like the o-ring sits in the groove low...so I'm guessing oil sneaks through. It's a small amount and nothing like before.
Ah, hope you can give me some advice!
OH, and picture.
ghost civic
Jul 27, 2015 03:15 AM
Sandman2.0
Jul 21, 2015 09:03 AM
toonces
Jul 21, 2015 02:40 AM
Countrygirl1976
Jul 13, 2015 10:08 AM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
