coolster 305B
Old May 16, 2012 | 07:08 PM
Chaser2178's Avatar
Default coolster 305B
I need some help with my coolster atv. When i try to start it all i can get it to do is click form the starter relay. I charged the battery thinking that was it still nothing. Took a test light and test to see if power was getting to the starter and it lit up when a pushed the starter switch. Could the starter relay still be bad even though power is passing through it. thanks
JDW
Old May 17, 2012 | 02:45 PM
Jaster94's Avatar
ok, just because you had the battery on a charger doesn't mean it took a charge. get a multmeter/ohm meter, check the battery voltage before you crank the engine/starter. then, hit the starter button and measure the battery's voltage simultaneously. what's that reading? we're eliminating variables as we go with these readings. be patient.
ultangler
Nov 30, 2024 01:35 AM
Whitelx1
Oct 2, 2015 10:55 PM
CoolsterSam
Sep 17, 2015 12:59 PM
Jersey General
1) Engine problems..
Sep 13, 2015 01:05 PM
raceman3
3) General Discussions..
Aug 10, 2011 07:12 AM
