Plugged exhaust
Old Aug 28, 2012 | 02:28 PM
Dsawyer44's Avatar
Default Plugged exhaust
I have been working on my grandson's LG50, Alpha Sports. It wont run after about 10 minutes of riding. I have disconnected the exhaust and seems to cure the problem. My question is, how to clean the exhaust. It seems like it doesn't have any restriction when you blow through it, but maybe it does when it heats up. Any suggestions would be appreciated.
Old Aug 28, 2012 | 03:31 PM
LT80's Avatar
LT80 Expert
I stick them in a fire/charcoal/etc. to get them red hot and blow compressed air thru.
Old Sep 1, 2012 | 08:38 PM
Need2ride's Avatar
Plug one end and pour HOT soapy water in and shake. Use a good grease cutting soap. Repeat a few times and flush, let dry.
If the chambers are big enough you can drop a few nuts and bolts in the mix and shake , knocks the carbon loose. Just remember to count your nuts and bolts so none get left behind .
I found this to work well on snowmobile expansion chambers
slowgsxr97
Mar 18, 2022 03:40 AM
STLyamwar
Jul 25, 2020 04:44 AM
traumajunkie
Jul 23, 2015 02:10 AM
HondaR24
Jul 21, 2015 12:12 PM
cSchwartz
Jul 12, 2015 07:42 PM
