LT80 Carb problems
Old Jul 2, 2016 | 10:40 PM
bcp385's Avatar
Default LT80 Carb problems
First I want to thank everyone on here for all the help I have gotten so far just from reading archived post! I have decided to join the forums because I am at a loss on this problem. 1996 LT80, stock motor, carb has been replaced but I believe it is stock as it has the vacuum ports on it. When I bought the quad it had the common petcock problem. Someone had added a plastic fuel cutoff and everything was fine, never even had to cut it off, no case flooding problems. I added a fuel filter and the fuel line became "crowded looking" and just looked awful so I decided to replace the petcock. Based upon Jack's recommendations I purchased a new, OEM, Yamaha Banshee petcock and installed it. One thing I did notice was when I pulled the fuel line from the carb the brass fitting came out with the line. I could not see any solder marks or anything like that so I just pushed it back into the carb. All new fuel line and filter, looked good and clean. First thing that happened was the case flooded while my daughter was riding it. I found that I had to just barely open the petcock and everything was great. Now even with the petcock barely open I have a steady drip at the bowl of the carb. It runs like a scalded dog but is leaking pretty good. The fuel is not coming from the drain line either
Old Jul 5, 2016 | 11:38 AM
DirtDevil101's Avatar
Any chance you could better trace the leak? You mentioned the brass nipple pulling out with the fuel line...curious if fuel is leaking from there. A strong light will help...
After adding the petcock, you plugged the vacuum lines...correct?
Our LT80 has flooding issues as well...I crack the petcock a bit and all is good, but always shut it off when not running.
Old Jul 5, 2016 | 11:52 AM
bcp385's Avatar
I don't think it is coming from where the line goes in. Vacuum lines are all plugged off as well. I've ordered a new carb and a rebuild kit. Going to put the new one on, rebuild the other and keep it out you for a spare.
Old Jul 5, 2016 | 02:08 PM
Is it weeping from the bowl gasket or higher up? In any event the float valve should cut off the flow of fuel when the bowl's full...make sure they are replaced or cleaned really well.
I replaced my float valve seat & valve...didn't help...so now it's a new float...
Old Jul 5, 2016 | 04:54 PM
bcp385's Avatar
Hard to tell where it's really coming from. At first i thought the bottom of the bowl had a hole but it does not.
Old Jul 6, 2016 | 11:25 AM
Maybe the drain plug...
Poolshark588
Feb 20, 2016 02:41 PM
JunkQuad
Feb 19, 2016 10:59 PM
amalota
Feb 5, 2016 01:45 PM
GregM
Jan 18, 2016 11:12 AM
yamahawk
Jan 16, 2016 12:44 PM
