Yamaha zinger quad help will not move with son on it
Hi I'm new to the site and need some help with my sons Yamaha zinger quad 2 issues
It runs but smokes a lot
And
It will not move with a 35 lb kid on it the wheels spin when I lift the rear up but stops when I put it back do
Any ideas I would like to get it moving first then control the smoking issue
Thanks
And
Thanks
One might fix the other.
I'm not a 4 stroke guy but I'll throw some things out.
Compression. Low may mean valves need adjusted or the piston is wore.
I'm unsure if a 4 stroke pipe could build up enough carbon to plug them off (like 2 strokes can).
Have you cleaned the carb?
My daughters first quad was a moto-4. Ran ok but the most gutless thing ever.
I do not know much about this thing it is a 2 stoke motor. It ran ok last fall but smoked started to slow down so put it away for the winter. Would not start this spring finally got it running new plug choke was stuck water in fuel cleaned out muffler
Now it starts fine but will not move with son on it other than down hill
