Suzuki won't run right
Old Apr 12, 2022 | 06:53 PM
djshad1469's Avatar
Default Suzuki won't run right
I'm helping my neighbor to try to get a Suzuki quadsport 50 running. Not sure of year, but probably around 2005. Clean tank. Replaced petcock, fuel lines, carburetor and spark plug. Started up and ran, but seemed like it starved for fuel when throttled up. Found a thread online about a seal on the crank coming loose and causing loss of vacuum. Checked that. Nope. Soaked original carb in cleaner for 2 days and reassembled. Same result. Ran a remote tank and line directly to carb. Same result. I'm thinking it can't be fuel related. Any other ideas?
Old Apr 13, 2022 | 03:42 AM
I assume we are talking of the 2 stroke? If so, I would check the exhaust, both silencer and the port. Had one that seemed "coked up" but silencer seemed OK. Our local Yam dealer told me that they coke up in the port. Checked and there was a curtain of carbon right next to the piston with a small hole in it.
Old Apr 13, 2022 | 05:17 AM
djshad1469's Avatar
Thanks. I'll check it out.
Old Apr 13, 2022 | 09:44 AM
LT80's Avatar
LT80 Expert
I'd check the compression.
Old Apr 13, 2022 | 08:32 PM
djshad1469's Avatar
Compression is 85 psi. Would that cause the loss of power when throttling? Will try to check the exhaust tomorrow.
Old Apr 14, 2022 | 10:15 AM
LT80's Avatar
LT80 Expert
Comp should be 90 minimum, 85 isn't far off, but yes, it can make it bog on throttle
zigs454
Dec 6, 2023 04:08 AM
86qscamo
Sep 3, 2009 08:01 AM
mrwil
Jul 20, 2009 01:42 PM
SuziOzark
Apr 20, 2009 06:03 PM
d_odom1600
Sep 14, 2008 01:11 PM
