Loose bolts
Old Feb 10, 2002 | 12:39 AM
CornDog's Avatar
as i mentioned in another post, the bolts on my sprocket came loose soon after I checked them and wore away at the side of my swingarm. it took a pretty good chunk out of the swingarm, so I advise you to make sure your bolts are tight every 30 minutes or so, because I had only been riding a little. i emailed cannondale about this so hopefully they will do something to stop this.
Old Feb 10, 2002 | 12:59 AM
OregonMXracer's Avatar
what would they do to fix it? Use loc-tite, and thats about it. The stuff isn't expensive, just go through your machine one night and put it everywhere. Have you had to adjust your valves yet CornDog?
Old Feb 10, 2002 | 12:21 PM
4strokemadman's Avatar
CornDog,
Because the sprocket is aluminum and the carrier is aluminum they take a "set" due to the bolt tension. If you torque the bolts back up to the correct spec the bolts shouldn't come loose again. I beleive the manual talks about tightening these bolts up after about an hour of riding. Loctite always helps but if the bolts aren't torqued correctly it won't help. Overtightening will just stretch the bolts and cause them to come loose as well.
Old Feb 11, 2002 | 01:25 PM
evhwg's Avatar
4strokemadman is right.
you best be using a torque wrench when doing any maintenance. to much is bad and to little is bad ..and a bunch of bolts not at the same torque is bad
Joe454
Nov 20, 2020 01:19 PM
MeadowlarkFarm
Nov 27, 2019 08:40 PM
EIF
Apr 20, 2017 07:15 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
