KNOWSALOT V/S BANJO BOLT
Old May 30, 2002 | 10:29 AM
jcv400ex's Avatar
The Banjo bolt I'm guessing as the culprit, would be the one you remove to drain the engine oil on the right case.
Now, do the holes have to line up with anything once the bolt is torqued down? Could you guys be torqing the bolt down too much, and causing the holes not to line up? Or are the washers worn out and shorter from tightening the bolt down? This would cause poor alignment, resulting in higher oil pressure. I might be wrong, but I'd check it out.
Old May 30, 2002 | 10:59 AM
trout's Avatar
Guys I took my biketo the dealer yesterday. There were very few motors that have this problem and most of you on this forum have the new motor. MY cannibal was one of the FIRST ones off the production line. #24 so it was in the first week or so and it had the old FX engine in it. I have talked with Cannondale and my dealer and my dealer is really good. IF you havent had the problem or just had it once there is no need for concern. My engine was leaking oil while idleing and running and considerable amounts. Thats differnt than a little engine oil heating up and comming our of the blow by tube that runs to the airbox, that is actually the design. YOu can pull that tube and look in it, some of them have a little glue that blocks the hole of the tube and creates pressure. YOu can just scrape the glue out and your problem is solved, the engine itself is solid.
Old May 30, 2002 | 11:56 AM
haulin's Avatar
Well, there you have it. Thanks everybody.
Old May 30, 2002 | 12:40 PM
Mxracer98's Avatar
Your talkinf about the tube that comes from the air-box right?
Old May 30, 2002 | 12:42 PM
  #15
trout's Avatar
yea, and there is another tube that cannondale27 talked about that runs down the right frame spar, that is the one that has the holes drilled or whatever on it. There should be two holes I think, but I may be wrong. We never talked about that with cvannondale or the dealer.
Old May 30, 2002 | 01:02 PM
  #16
briansgi's Avatar
Trout, did you buy a refurbished unit? I'm trying to figure out how your quad is still under warranty being vin #24 unless you purchased a refurbished unit or maybe you bought some kind of extended warranty??
Old May 30, 2002 | 01:14 PM
  #17
trout's Avatar
no its 24, it must have sat in the showroom or warehouse for along time. I purchased in march, cant argue with the receipt....
Old May 30, 2002 | 07:41 PM
  #18
Mxracer98's Avatar
Kyle called me back on said, he talked to mark at cannondale and that the bolt where you change your oil should have 2 holes in it and that there are two of the same in the air box. He also said that the hose by the cam cover- they apoxied it and he has seen apoxy in the hose there and too check that too.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
firsttimerider
Sep 20, 2015 09:07 PM
Canamaniac!
Sep 15, 2015 06:19 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
