BIG GUN EXHAUST!!!!
Old Aug 19, 2002 | 12:22 AM
Derno24's Avatar
51 hp that has got to be from the crank and not at the raer wheels. Otherwise you are talking a 18 hp jump from the 33 rhp. I got the HMF and it really rips sounds excellent too. Another guy on an fx400 has the Big Gun he said mine felt a little faster. That could just be the newer model and all.
Old Aug 20, 2002 | 11:42 PM
cdalepaul's Avatar
hey derno what do you think about the blaze map?? how much of a differece between the cannibal and the blaze map??
Old Aug 21, 2002 | 08:00 AM
dawzie's Avatar
Just something that happened to me. I have Pep's ZPS shocks. When the Big Gun pipe was mounted in the factory position it would hit the axel and nut. I had to raise the pipe, AFTER I saw a dent (darn it) in the new pipe.
Old Aug 21, 2002 | 12:20 PM
Derno24's Avatar
cdalepaul: the blaze map definitely gives you more top end and it pulls harder in the mid range than the cannibal map. It is close to just a cannibal map with more power at the top is probably the best way I can decribe it. I have the Diag/Main sysytem when I start to play around with the different maps I will give you a better report.
Old Aug 21, 2002 | 02:44 PM
  #15
cdalepaul's Avatar
thanks derno and the others for the help
Pehter
Oct 3, 2024 11:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
cboler9
Sep 24, 2015 08:35 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
