OMF Radiator Shrouds
Old Oct 1, 2002 | 12:58 AM
Derno24's Avatar
I ran the clutch cable around the shrouds now I have no freeplay in the clutch any suggestions.
Old Oct 1, 2002 | 12:52 PM
jcv400ex's Avatar
Derno,
RetroZ is running one of my radiator guards. This was his comments on it. I'm guessing he had the same clutch trouble as you????
"I put the guard on and it looks good. The only thing is that I have the old clutch routing and had to cut a new hole in the radiator fin. I was going to cut the guard, but I just move the hole forward and up at a 30 deg angle. It changed the cable pull and made it much easier than before. The boring Geometry class pays off sometimes. Just let the people know before they buy it. Some people out there are not too bright and would rather blame your guard then just figure away around it."
Old Oct 1, 2002 | 05:35 PM
Derno24's Avatar
I am curious does this mean I have to drill a hole in the shroud or does it mean I can just change the angle on the clutch somehow???
Old Oct 1, 2002 | 11:05 PM
jcv400ex's Avatar
I'd PM retroz. He should be able to explain it to you. After he does, let us know!
Old Oct 4, 2002 | 01:02 AM
armoks's Avatar
if you have the older cable cluch like mine you might want to look at the tech page PB02-001 it shows the longer clutch cable and part numbers that could be a solution for you
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
panicmanic
Sep 28, 2015 12:59 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Logan Collins
Sep 5, 2015 08:03 PM
