Feeeel Tester's Mighty POWERS!!
Old May 20, 2003 | 05:19 PM
  #21
LapTraff1c's Avatar
Default Feeeel Tester's Mighty POWERS!!
I have a dog named "Fester"
Serious. I was in a weird mood when I named him.
Old May 20, 2003 | 10:22 PM
  #22
onebigwig's Avatar
I just bought a new Cannondale Cannibal. Yes, I know they just filed chapter 11. Anyway, I did the one hour "break in" and during the first service the clutch was adjusted because it was "loose" (not engaging in gear until the clutch was almost fully released) . After another hour of riding the clutch was loose again. The dealership is saying I need new clutch plates. Two hours of riding, whats up?? Suggestions??
Old May 20, 2003 | 10:50 PM
  #23
CANNIBAL440's Avatar
Either the clutch was never adjusted properly before you picked up your new quad (causing you to burn it up), or you need to learn how to use a clutch you don't need to slip them as much as on a 2 stroke). Without knowing how you treated your quad, it is hard to say which is the more likely cause. Good luck!
Old May 20, 2003 | 11:02 PM
  #24
onebigwig's Avatar
I specifically asked the dealer how to avoid this problem so I was very careful, however I assumed the clutch was adjusted correctly when it was delivered to me new. Would your best guess be that the clutch was burnt up in the first hour I rode it when the clutch was loose to begin with?
MeadowlarkFarm
Nov 27, 2019 08:40 PM
fordfaithful21
Dec 7, 2015 05:52 PM
byronman
Sep 6, 2015 06:34 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
Logan Collins
Sep 5, 2015 08:03 PM
