4 stroke and 2 stroke
Old Sep 13, 2003 | 05:46 PM
RuffRyderz's Avatar
Default 4 stroke and 2 stroke
can anyone explain these to me? whats the difference whats better?
Old Sep 13, 2003 | 06:04 PM
hotseatperformancefan's Avatar
alright a 4 stroke uses straight gas like a car and a two stroke uses a gas oil mix. a 2 stroke usually makes more hp and has more upgrades. a 2 stroke is easier to work on too.
Old Sep 13, 2003 | 08:57 PM
dragracer789's Avatar
A 4-stroke also has a cam and valves. A 2-stroke dosent. A 2-stroke has reeds. A 2-stroke firers every stroke and a 4-stroke firers every other time. Thats why a 4-bangers need a cam and valves.
Old Sep 13, 2003 | 09:47 PM
TrailBlazerguy250's Avatar
and a 2storke it takes one rotation to make a power stroke and a 4stroke takes 2 rotations thats why aq 4 stroke has more power and a 2 stroke is faster
Old Sep 14, 2003 | 01:01 PM
RuffRyderz's Avatar
oh just like cars kinda
Old Sep 14, 2003 | 01:04 PM
RuffRyderz's Avatar
how can u tell just by lookin at a fourwheel if its 2 stroke and 4 stroke?
Old Sep 14, 2003 | 02:23 PM
FTZLT250r's Avatar
To me, the biggest difference is $$$ for rebuilds.
Let's say you cook your 2 stroke.... You can get a bore job and piston for under $200.
Let's say you cook your 4 stroke..... This is an extreme example, but a guy that races with us just spent $2,200 to get his 4 stroke rebuilt. He had bent valves and all. At that point, I would have to let the quad sit.....
Old Sep 18, 2003 | 10:39 AM
chipdog4's Avatar
The quickest way i can tell if a wheeler is two storke or not is if you see the expansion chameber on the exhaust. If it's four stroke, it will be the same diameter pipe all the way to the muffler. You can also tell by looking at the head. If it's flat and has a plug sticking straight out the middle, good chance its two stroke. Four stoke plugs usually go into the side of the head.
Old Sep 18, 2003 | 03:10 PM
AlphaRaptor660R's Avatar
you could also tell them apart just by the way they sound..4-strokes make a loud thumping sound and their silencers are usually a little bigger than 2-stroke silencers...2-strokes sound like they are really wound up....
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
