Has anyone tried mothers plastic polish??????????
Old Sep 19, 2003 | 04:48 PM
tealsandtails's Avatar
Default Has anyone tried mothers plastic polish??????????
I tried novus- no luck, anything i can think of- I tried. trying to get surface scratches out and make this bike shine?? Just tried wax and it dulled the finish!![img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Sep 19, 2003 | 09:07 PM
DaSandBomb's Avatar
try fomula 2000 its in a lime green bootle, it works good, it takes the scrathes out alittle.
kc
Old Sep 21, 2003 | 09:32 PM
KSmotoXer15's Avatar
i used novus last week and made my EX plastic look brand new, the secret is using a buffer, but you have to be careful or it will burn little gouges into your plastic. i was very impressed. i had to do the same with mothers polish.
Old Sep 22, 2003 | 09:44 PM
Hey guys, I was afraid a buffer would leave swirls, but I'll give it a try. You know what I JUST FOUND OUT!!
Someone said spray silicone, for shine, and water & mud falls right off!!!!!!!!!! What do ya think? Cycle shop said try applying a hair dryer.
Old Sep 22, 2003 | 10:30 PM
RookWV's Avatar
That'll work for mud and heavy stuff but dust and lightweight grime will settle and stick to it....I'd rather the mud come off easy though....
I use Formula2001 since the spray silicon is usually too thick and leaves too heavy of a coat....
Old Sep 22, 2003 | 10:38 PM
95wolv's Avatar
A buffer will work, but you should use a foam bonnet, the cloth one will heat up the plastic if you're not careful.
Old Sep 23, 2003 | 09:53 PM
How often do you use Formula 2000? do you let it sit for a while or do you wipe it off right away????
Old Sep 26, 2003 | 04:45 PM
BALLS2THEWALLS's Avatar
try getting new plastic.....worked for my friend and im gonna try the same[img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 1, 2003 | 08:36 PM
Inginegirl's Avatar
After a good washing,
Try spraying WD30 on it and wipe down good. If you are only looking for a bit of a shine
and the mud will slid right off. But it won't cover scratches.
Where we ride is mostly muddy trails and it makes my quad look brand new.
Ride safe.....[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 7, 2003 | 02:41 PM
erno's Avatar
Next time you are servicing your quad retain the engine oil in a long cylinderical can for 24 hours , drain off top to within 1" of the bottom , wash quad and apply oil with soft cloth. Totally restores plastic plus foot guards like new. I discovered this by accident and highly recommend it.[img]i/expressions/face-icon-small-happy.gif[/img]
wendal
Aug 3, 2024 10:03 PM
Joe454
Nov 20, 2020 01:19 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Elkaholic
Sep 6, 2015 02:44 PM
Brandon400
Sep 5, 2015 08:44 PM
