UNI Filter HELP
Old Mar 27, 2004 | 08:30 PM
mojavekid13's Avatar
Default UNI Filter HELP
hey guys,
I have a CR125 with a UNI foam filter,
Today i took it off and cleaned it out real well with gas, and soap and water.
Its now dry and Iam woundeing if there is anything i need to put on it,
i heard from some one that you put on 80/90 gear oil? But that dont sound right o me
Thanks guys
Old Mar 27, 2004 | 08:49 PM
caliraptor's Avatar
If you dont have UNI Foam FIlter Oil, just use regular engine oil. I used Yamalube like 2 weeks ago and it worked fine.
Old Mar 27, 2004 | 10:14 PM
What about that RED chainsaw oil, ?? Almost looks teh same as K&N oil
And How do i put it on??
Do i just pour a little bit of motor oil on it and let it soke in or what?
Old Mar 27, 2004 | 10:25 PM
crispy's Avatar
what you wanna do is pour some in your hand then just kinda kneed it into the filter, just work your hands over the filter. it's very simply, just a pain in the *** to get your hands clean
Old Mar 27, 2004 | 10:28 PM
So would Jus regular Motor oil work?
What do you think about 80/90 gear oil
and what do you think about that red chain saw oil??
Thanks
Latter
Old Mar 27, 2004 | 10:55 PM
roosthrower's Avatar
I would use the chain saw oil just because it is probably two stroke oil. and if your motor sucks down some extra two stroke oil it wont hurt anything
Old Mar 27, 2004 | 11:04 PM
geoliquid's Avatar
try this... through the filter into a plastic grocery store bag. add your oil to the bag and work the oil into the filter. This works great for me and not only does it keep my hands clean but it makes a bottle of that uni filter oil go a long way.
Old Mar 27, 2004 | 11:07 PM
How much oil are we taking hear?
Liek Sould i pour it right o to the filter, or in the insider or what?
and how much shoudl i add about 8-10 cap fulls?
Old Mar 27, 2004 | 11:08 PM
Thansk guys.,
Its just i have never doe it befor, and i want to do it right the first time,
If it was a K&N paper filter, i would have no problems, Firast time for teh Foam stuff
Old Mar 27, 2004 | 11:10 PM
Hozed's Avatar
red chain saw oil... i assume you mean bar and chain lube... id use engine oil if i had a choice between the 2....
i also put the filter in a bag and pour the oil in... like said above... just kneed it into the filter... i cant say how much you will need... but you want to cover the whole filter pretty well. when its covered... your done...
