arc welding tips/help
Old Dec 1, 2004 | 09:16 PM
  #21
mystereid's Avatar
It's official, I've been duning for over 30 years.
Default arc welding tips/help
Aloe vera makes the pain go away[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 4, 2004 | 08:33 PM
  #22
moldycheese's Avatar
i got one for ya, DONT GET UR FINGERS IN THE WAY!!!! especialy if u weld the man way (no gloves)
Old Dec 5, 2004 | 02:30 AM
  #23
elkbow's Avatar
speaking of welders....you can use an arc welder for limited use, they work okay limited uses...
I picked up a Miller Millermatic 251 Mig Welder with 30A spoolgun....I can weld up to 1/2" with no problem and can go up to 3/4" with multiple passes.....
of course, it runs on 240V, so had to do alittle rewiring in the circuit breaker panel in the garage...
the 30A spoolgun is for welding aluminum.....
dave
Old Dec 5, 2004 | 08:05 AM
  #24
jpsdiving's Avatar
Miller makes a good machine dave, I have the same set up with a lincoln.
Old Dec 5, 2004 | 02:00 PM
  #25
elkbow's Avatar
Lincoln and Miller seem to have similar models, almost look the same too....almost like someone makes them for them.....its like the ATV manufacturers, can't be outdone, have to come up with something new and improved and compete against each other....a competitive marketplace is a good thing though...
The Millermatic 251 is a breeze welding steel, doesn't take alot of skill rather than making a few setting changes and having a steady hand.....I'm playing with the 30A spoolgun today, to weld aluminum....thats alittle harder to master....
dave
Old Dec 5, 2004 | 02:54 PM
  #26
jpsdiving's Avatar
Dave, take a look at my pics. I welded the swim platform with my spool gun. The spool gun is a breeze to use, just hit some scrap first.
Old Dec 5, 2004 | 03:25 PM
  #27
elkbow's Avatar
which pic are you talking about, don't see a swim platform...
anyways, having a hell of a time, burning up tips in the nozzle.....i stainless steel wirebrushed the crap out of the aluminum....i'm running about 35 cfm pure argon and using marine grade aluminum wire....not sure what is going on, not enough voltage, too fast of wire feed, too slow...not sure....
update: backed argon down to 25 cfm, i don't think i have enough wire feed, it always wants to burn the wire back up towards the tip....any advice, not sure whats going on....been playing with different settings.....how far away is your tip from the aluminum when welding? how much voltage are you using?
dave
Old Dec 5, 2004 | 05:13 PM
  #28
jpsdiving's Avatar
Dave- I will IM you my phone #, and I will walk you through it.
Old Dec 7, 2004 | 10:41 PM
  #29
Kushman's Avatar
Blue Thumb....they are killin me LOL
Valder
Nov 28, 2020 07:38 AM
bigred20653
Oct 2, 2015 10:05 AM
greg86hd
Sep 16, 2015 12:32 AM
DFWSRT8
Aug 20, 2015 09:24 AM
MNatv89
Aug 12, 2015 06:00 PM
