what is pre-detonation.
Google, it's a wonderful thing...
Definitions of detonation on the Web:
a condition, in which, after the spark plug fires, some of the unburned air-fuel mixture in the combustion chamber explodes spontaneously, set off only by the heat and pressure of air-fuel mixture that has already been ignited. Detonation, or "knock", greatly Increases the mechanical and thermal stresses on the engine.
www.autocenter.com/about/
A violent explosion involving high-velocity pressure waves; in a gasoline engine, the spontaneous combustion of part of the compresses charge after spark occurs. Detonation usually produces a characteristic metallic sound, or knock.
www.alken-murray.com/fuel-glossary.htm
the ignition of the fuel air mixture before the piston reaches top dead center.. this is a bad thing!!
http://www.warrixflyinggroup.co.uk/A...reminology.htm
An uncontrolled pressure rise and the associated heat rise caused by the reacting of the fuel in the combustion chamber. This is usually associated with the pinging sound you here from engines as multiple flame fronts collide in the combustion chamber.
http://www.eric-gorr.com/techarticle...erminology.htm
Uncontrolled burning of the last portion of the air/fuel mixture in the cylinder of a spark ignition engine. Also known as "knock" or "ping".
www.caltex.com.au/products_glo.asp
A single nuclear device explosion; one or more comprise a test.
www.lanl.gov/history/hbombon/glossary.shtml
The molecular breakdown of a substance brought about by shock. Initiated by detonator.
riv.co.nz/rnza/hist/terms.htm
is a rapid explosion of fuel in the cylinder in advance of the spark plug firing. It can generate enough heat to melt the pistons and in other ways destroy the engine.
www.m-20turbos.com/definitions.htm
An action that results in hits on every unit near the detonation.
www.ccs.neu.edu/home/woj/xconq/xconq_427.html
This is a supersonic combustion wave. Detonations in gases propagate with velocities that range from 5 to 7 times the speed of sound in the reactants. For hydrocarbon fuels in air, the detonation velocity can be up to 1800 m/s. and is a function of the reactant composition, initial temperature and pressure.
http://www.sysman.co.za/Xplo/Xplo_de...n_of_terms.htm
explosion: a violent release of energy caused by a chemical or nuclear reaction
the act of detonating an explosive
wordnet.princeton.edu/perl/webwn
Detonation is a process of supersonic combustion that involves a shock wave and a reaction zone behind it. The shock compresses the material thus increasing the temperature to the point of ignition. The ignited material burns behind the shock and releases energy that supports the shock propagation. This self-sustained detonation wave is different from a deflagration that propagates with a subsonic speed and without a shock. ...
en.wikipedia.org/wiki/Detonation
Find definitions of detonation in: English French German all languages
LOL [img]i/expressions/face-icon-small-wink.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img]
Originally posted by: IdahoVinnie
Yes, <u>that's what I said!</u>
I think this has been covered pretty well. [img]i/expressions/face-icon-small-wink.gif[/img]
