Chain lube
Old Feb 4, 2006 | 10:11 PM
kl's Avatar
kl
Default Chain lube
What is the best kind of chain lube that dont come off as soon as you ride.
Old Feb 5, 2006 | 02:08 PM
recon99's Avatar
Default Chain lube
Any kind of real chain lube should stay on the chain when applied right. I've used both Bardahl and PJ1 and they have their advantages and disadvantages. The PJ1 makes less of a mess, it isn't as sticky and none of it flings off. It doesn't seem to last as long as the Bardahl lube, which is thicker, stickier, and messier. The bardahl stands up to water better than PJ1 also. It's just a real pain in the @ss to get off your swingarm and everything else after you apply it. My suggestion for that is to lay down newspaper on the swingarm and surrounding parts before you spray it on, and let it set for 10 or 15 minutes before you ride again.
Old Feb 5, 2006 | 02:43 PM
YFZracer12's Avatar
Default Chain lube
I use PJ1 but when i go to the dunes or ride alot in sand i use WD-4D keeps the chainfrom rusting and helps lube it while in the sand
Old Feb 6, 2006 | 01:12 AM
Doctorturbo's Avatar
GOT BOOST!
Default Chain lube
I personally NEVER X 100,000,000 use a sticky chain lube. Been there done that. I would use a good chain wax. Better than that, I would get an O ring chain and never use anything.
Old Feb 6, 2006 | 10:32 AM
recon99's Avatar
Default Chain lube
Never use anything? You don't have to lube an o-ring chain? If so, that's new to me. Why would they make o-ring safe chain lub if there's no reason to? I've always had o-ring or x-ring chains and i always use chain lube on them.
Old Feb 6, 2006 | 11:09 AM
GOT BOOST!
Default Chain lube
If you own a chain lube company would you say never use a chain lube on an O ring chain? It's all marketing.
I forgot the figures but it's something like 90% of wear occures between the rollers and the pins. When this happens, the chain stretches and gets longer and then the sprocket valleys do not line up with the rollers. There is no way to get lube in between the pins and rollers on an O ring chain because it's sealed.
I live around a volcanic area. I have seen chain go away in a matter of days if someone uses a sticky chain lube on them. If you use a sticky chain lube where I live you might as well brush some valve grinding compound on the chain.
Old Feb 6, 2006 | 11:39 AM
recon99's Avatar
Default Chain lube
This is the first time I ever heard someone say that you don't need to lube a chain. The biggest chain issue where I live is riding in water. I use lube to preserve the o-rings so they don't wear out and let water into the rollers, and to keep the chain and sprockets from rusting. If I didn't use lube my chain would be a solid strip of rust within a month.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
