Chinese atv- how to tighten chain
Old Dec 31, 2007 | 02:55 PM
dUrTwErX dEsIgNs BMX's Avatar
Default Chinese atv- how to tighten chain
I bought a couple Super Machs recently(I think they are similar to rocketta), On my larger 110, my kid got jammed up with a pretty large stick, and popped the chain, he managed to get the chain back on it and get the atv back to the garage, but now the chain seems pretty darn loose, esspecially on the bottom. Can anyone point me in the right direction of how to tighten the chain?
Any help is appreciated.
BTW, it is a loncin 110cc engine, and is the mid-large size 110 purchased from PowersportsMax.com
Old Dec 31, 2007 | 03:28 PM
anyone?
the kid is drivin me nuts, I gotta get it snugged up. lol
Old Jan 1, 2008 | 11:36 AM
ss97's Avatar
Lets Ride!
I think people would be happy to help.... I just don't think anyone can without actually seeing the set up...... some of those Chinese ATVs I've seen are set up pretty strange.
There must be some adjusting bolts or nuts on the rear axle.
Old Jan 1, 2008 | 11:43 AM
There is a picture of the rear here:
http://www.powersportsmax.com/...ath/37/products_id/595
Oh, and HAPPY NEW YEAR ALL!!!
Old Jan 9, 2008 | 01:24 PM
ATVConfuzed's Avatar
My sons have 110's and the older one throws his chain off a lot. Trying to figure out why - any suggestions? Anyway, it's the same as the picture you referenced and the screws are on the bottom in the midle. Loosen the lock nut inside the bracket and tighten the two nuts on the back of the frame visible in this picture http://www.powersportsmax.com/...ATVs/ATV-P21/11-l.jpg
Good Luck
Old Jan 9, 2008 | 01:49 PM
<div class="FTQUOTE"><begin quote>Originally posted by: ATVConfuzed
My sons have 110's and the older one throws his chain off a lot. Trying to figure out why - any suggestions? Anyway, it's the same as the picture you referenced and the screws are on the bottom in the midle. Loosen the lock nut inside the bracket and tighten the two nuts on the back of the frame visible in this picture <a target=_blank class=ftalternatingbarlinklarge href="http://www.powersportsmax.com/images/ATVs/ATV-P21/11-l.jpg
">http://www.powersportsmax.com/...TV-P21/11-l.jpg
</a>
Good Luck</end quote></div>
awesome. Thanks.
About your 110 throwing chains...did the sprocket get bent at all? or the chain?
I remember back when I was youngI had a 90cc Kawasaki dirtbike that kep throwing chain...I was so discouraged, I replaced the sprocket twice, made sure time and time again that everything was lined up, Finally, I replaced the chain, and I never had the problem (with that bike) again. turned out that the cheap chain streached in a couple links causing it to pop off.
Old Jan 10, 2008 | 02:30 PM
Thank you. [img]i/expressions/beer.gif[/img]
We're going to look at it tonight and take some measurements. Hopefully we find the problem quick and simple. The sprocket was off and we lined it up so there is a good possibility that one side of the chain stretched more than the other.
Old Jan 10, 2008 | 07:54 PM
Good luck to ya.
Finally got around to tightening the chain for my kid, and tightening a few other things.
One thing that concerns me about this bike is the horible placement, and short hoses out of the carb. Do you have any recomendations of where to re-route them for safety reasons?
01ssls1
Sep 22, 2015 06:50 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
