ATV PLOWING
Old Feb 6, 2008 | 06:52 PM
  #21
zaptoad's Avatar
Default ATV PLOWING
I am just trying to give everyone a heads up on a possible problem, that's what the forums are for. I like my Mooses (std & Country), the Country throws higher. The berms are over 4' tall right now, so it works best. All I am saying is to check the welds on the short square tubing that runs between the 2 push tubes, it is only welded on 2 sides. It will crack there first, after that things start to get ugly.
Old Feb 8, 2008 | 12:46 AM
  #22
ArcticRescue01's Avatar
Default ATV PLOWING
So what about a universal mount? Arctic Cat has a Great looking plow. The plow is made of polycarbonate (Thick Plastic) and steel frame that it is mounted to, then the push tube is steel, but I am wondering if this blade would fit any universal mount push tube?
Old Feb 8, 2008 | 12:28 PM
  #23
zaptoad's Avatar
Default ATV PLOWING
I have wondered about that too. Polaris makes a blade (GLACIER I PLOW ) that is shaped like a BOW TIE, so that it lifts snow angled either way. My Moose Country blade only lifts when angled to the right. Are they universal fit, will a Polaris blade fit on a Moose push tube? Is anyone using this plow and have any thoughts about it. I like the way it looks!
http://www.donwoodpolaris.com/...IER_I_PLOW_SYSTEM.htm
So you have an idea as to what it looks like.....
Old Mar 13, 2008 | 01:04 PM
  #24
bowdenboyz16's Avatar
Default ATV PLOWING
my county moose lifts either way
Old Mar 18, 2008 | 01:08 PM
  #25
Default ATV PLOWING
anyone else plow around here or around maine
Old Mar 18, 2008 | 02:04 PM
  #26
Catpak's Avatar
Default ATV PLOWING
I plow in Wisconsin by the tip of Lake Superior. I'm a Engineer for our school district. I have a Polaris 500 ATP at work with the Glacier I plow....I don't like it as much as the one at home. It is a fast on and off plow..But the problem I have with it is... while backing up over curbs or frozen piles the bottom of the plow hits and unhooks itself from the rear. It really sucks trying to put it back on with all the snow under it.
At home I have a 08 700 TRV Arctic Cat with the Arctic Cat plow. I replaced the wear bar with a grader blade and removed the shoes.(same as work). I push a lot of snow with this rig. I live on a lake so I do a lot of cabins, skating rinks and the main road when the plow trucks don't come around. If the snow banks get to big for the wheeler..I have a Kabota tractor with a front end loader to push the banks back.
Which plow system do I like the best?? Arctic Cats hands down.
Old Mar 18, 2008 | 02:31 PM
  #27
zaptoad's Avatar
Default ATV PLOWING
Thanks for the heads up. I am in North Idaho, half mile from the county road and roughly a mile of driveway total. I don't like it when things break, it wastes too much time and its no fun standing on your head in the snow. Time in is the best, sounds like you've been there! For now, I'll stick with my Moose. Still waiting for the snow to come off here, can see gravel, but might be too early to take the blade off yet.....we will see..........
Old Mar 28, 2008 | 01:32 PM
  #28
Default ATV PLOWING
ya i took my blade off alittle to early also and i live in maine
shimanok2
Jan 29, 2016 07:37 PM
kampswas
Sep 23, 2015 05:05 AM
stcspiderman
Sep 13, 2015 05:15 PM
ylomnstr
Sep 10, 2015 06:45 AM
TheATVSuperStore.com
TheATVSuperStore
Sep 9, 2015 07:43 PM
