Trail Tech, is it worth $78 ??
Old Jul 20, 2003 | 05:16 PM
  #21
yellowexracer's Avatar
Default Trail Tech, is it worth $78 ??
I heard that trailtech is comming out with a new model that hooks up to your battery so it's backlit at night.
Old Jul 20, 2003 | 09:27 PM
  #22
HappaRap's Avatar
Lazy Boy Rider!
It's hard enough to see your speed when your going 70 mph down a gravel road, you're floating, and feeling alittle loose, now trying to do it at night!!! Ya, just kidding around, thats pretty trick backlit, even though I don't do alot of night riding, still cool.
Old Jul 21, 2003 | 07:02 AM
  #23
NLWarrior01's Avatar
Originally posted by: tmm2good
Vforcerider,
I see you used 1755 as your setting. I used 1676, which it listed as a 22 inch tire for the Honda. Did you measure your tire like they showed in the instructions ?
tmm2good;
The mm circumferance of a 22" tire is actually 1755.52mm. 22" x 25.4mm/" = 558.8mm diameter x 3.14159 = 1755.
1676 would be for a 21" tire.
Old Jul 22, 2003 | 01:49 AM
  #24
Vforcerider's Avatar
I think this model is back lit, isn't it?....... who reads instructions?? heheh
tmm2good.. yeah they tell you to sit on it and measure blah blah blah.. but I figure once I'm going at a good clip, I'm not really putting any pressure on the front tire.
Old Jul 22, 2003 | 01:54 AM
  #25
BigBadScrambler's Avatar
There is a backlight that stays on for 3 seconds when you press a button
Old Jul 22, 2003 | 02:40 AM
  #26
R00ST's Avatar
ok im looking at these on rocky mountain, and see the computer itself for like 80 or so bucks....now is this JUST the computer and hook ups? or does it come with the mount as well?
i ahve seen the handlebar brackets for various handle bars (even for trailtechs own handlebars) but they are like another 120 or so bucks....
does the 80 dollar speedo kit come with a mount?
(ive seen people mount it on the handlebars on an angle but that kind of annoys me...havin the screen facing one way or another...)
i will be mounting this on a ds 650 baja so i dont know if i could do the "fender mount"
any help is appreciated on this one
Old Jul 22, 2003 | 02:47 AM
  #27
I comes with a mount. Look at where I have it mounted in my pictures. I used the clamp on mount that came with it. If you want the billet protector that mounts to your handlebar mount, then that is extra.
Old Jul 22, 2003 | 06:28 AM
  #28
Vforcerider, placing pressure on the tire doesn't really change the rolling circumference anyway. The most acurate way to measure the rolling circumference would be to mark the tire and rolling surface (road, driveway or whatever) and then roll the machine for one complete revolution of the tire. Then mark the rolling surface again and measure the straight line distance travelled. Either measure that in mm, or in inches and convert to mm. All 22" tires differ in actual size slightly based on manufacturing tolerances, so IMO the rolling method is the best.
Old Jul 22, 2003 | 06:33 AM
  #29
The cheapest I found one for was 69.99 at Moto Man .. http://www.moto-man.com/catpages/trailtechatv.pg
As for the mounting, I mounted the computer on the clutch side of the handlebars using the supplied handlebar clamp. I'd have preferred to have it in the centre of the bars, but I couldn't get a convenient place to mount since the Warrior doesn't have a very good dash. I also wanted it to have some protection. It's really easy to install, and the unit is quite small, so it doesn't take up a lot of realestate on your machine.
Old Jul 22, 2003 | 06:38 AM
  #30
BigBad, nice installation location. I looked at putting mine on the cage around the headlights too, but the cage on the warrior is very small stock, requiring some custom work to do what you did. I was also afraid that if I tipped over, the computer has a good chance of getting broken up in the open like that.
Nice looking ride tho ;-)
