Adjusting Valve Lash For Performance
in the past on thumpers i have always adjusted the valves right in the middle between high and low spec, never really dyno'd on how to get the most horse out from valve lash setup. on a stock engine such as my warrior should the valves be looser or tighter for max peformance? i would think looser but not really sure. anyone know, just curious. tryin to get every last bit of horsepower out of my setups. thanks
mark
mark
thanks a lot man but i think i will setup so it has a little lash but on the tighter a lot tighter side. i tried that before on my mojave it it wouldnt start with no valve lash but worth a try. dropping a valve isnt the worse thing in the world. i have had much worse happen to me before.
bpegram84
07-22-2015 09:15 AM
