Best Yamaha Warrior Mods??
Ok, I need some mods to make my warrior lighter for massive jumping. Does any one have and suggestions to the best mods i can put on it for more stability and to make it lighter for jumping? Also is there any engine mods i can do to make it as fast as the new YFZ 450(im not sure there are any that can make it that fast without changing an engine) and also if anyone knows where i can get a kick start for a back up starter.
Thank You,
Bri
Thank You,
Bri
Add +2 A-arms and shocks, that makes a huge difference with stability. As far as making it as fast as a YFZ, that wont happen with the warrior motor, well you might be able to add nos. Mickey Dunlop makes a 450 kit but even with that you still only have 2 valves. I wish they made a kick start for the warrior, removing the starter and battery would take off some weight. The only other starting option is the older warriors had a pull start.
You answered your own question... Sell the warrior and get you a YFZ450 Your problems solved...
That makes your warrior lighter and as fast as a YFZ450 [img]i/expressions/face-icon-small-happy.gif[/img]
anything else will not even come close.........
Originally posted by: NLWarrior01
untrue!! It doesn't change anything about the warrior other than ownership [img]i/expressions/face-icon-small-happy.gif[/img] Still though, you'd have to spend the worth of a YFZ on a Warrior to even come close I'd say. There's just not much on a Warrior to lighten. You could order a custom titanium frame .. that would save you a good bit. loose the front bumper, get lighter wheels and tires, new shocks ... they sky's the limit as long as you got the $
I did say that it would cost you more than a new YFZ to get the Warrior even close ...
As for why spend the money?? Some people have more $$ than ¢, a problem I don't have, but sometimes wish I did [img]i/expressions/face-icon-small-happy.gif[/img]
