best engine kit for banshee
Old Jan 14, 2004 | 06:43 PM
cRazyJ's Avatar
Default best engine kit for banshee
what company makes the best banshee motor kit, also what are the best high compression piston
Old Jan 14, 2004 | 07:47 PM
AngryHampster's Avatar
i'd say WISECO for the piston, from personal experience, for the banshee, check out Trinityracing.com...theyve got a 535 big bore kit guaranteed for 125HP without nitrous.
Old Jan 21, 2004 | 12:08 PM
AlkyBurninX's Avatar
Well first off, you don't change compression in a two stroke by changing the piston.
"kits" aren't where the optimum hp is at. Custom built engines are best.
Old Jan 22, 2004 | 07:24 PM
havinnoj's Avatar
What kind of riding do you do? That will be the best way for us to let you know what we recommend.
Old Jan 23, 2004 | 07:07 AM
Zilladaddy500's Avatar
Call Vito's performance he won't let you down,I've delt with him when he did engine work and he made my Zilla one bad machine,He's in Dirt Wheel's Mag. or call...(248)969-9168 and ask him anything he will ask you what type of riding you do,anything.....
Old Jan 25, 2004 | 01:51 AM
sandbomber's Avatar
Lots of good builders out there. Where are you located.
Old Jan 25, 2004 | 12:22 PM
madracing's Avatar
i have seen the trinity 535 run and its for real. but its not a play rider, they have a 440 that is a good duner. harry has these motor packages in stock a builder sometimes can take a while to get your motor back. if they are good they are in demand so it can take months for a turnaround
Old Jan 26, 2004 | 10:45 AM
In stock? There really isn't any way to "stock" an engine package for a motor like this. What I mean is you send YOUR cylinders and have them ported to fit your needs, or they take aftermarket cylinders and port them to fit your needs. They weld your crank when they get it from you or they use new cranks that they have laying there for any engine that needs it. The heads are the same way. My point is, they might happen to have the parts that you need but they don't throw a crank, head, reed cages, carbs, etc in a box and let it sit until someone happens to need that exact setup. There are too many variables.
Old Jan 26, 2004 | 05:39 PM
DaBeechMan's Avatar
actually harry has cranks sitting in boxes. Sometimes he runs out and he orders them, but he generally will carry cranks to fill orders. Cranks take a long time to produce so mass ordering them will ensure he will have them when the demand is needed. Pistons can change compression by reallocating the pin height, and dome design (flat top, round top, ect)
Cylinders are casted for different reasons to fit different needs. Pro-x cylinders are better track and dune motors. Cheetah's are good drag motors, as are t-rex's and SS motors. If i were to build a banshee now it would be a t-rex banshee. The cheetah's are casted to the point where there isnt much variation between them to constitute trying to be the fastest.
Depending on the cylinder you run there are better pistons being made for them. Again, depends on what you want.
Ive seen more then 2 535 cheetahs that trinity did that didnt even hit 115 on their own dyno with harry tuning it.
If you have any questions PM me. I know about most of the cylinders out there if you need help
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
