400ex plastic on a 250r
Old Jun 28, 2000 | 01:26 AM
ronhonda's Avatar
would like some information on installing 400ex plastic on a 250r. I tried calling performance racing products and the number was disconnected. also will I be able to use an aftermarket gas tank with this conversion? thanks in advance on any info sent.
ron
Old Jun 28, 2000 | 04:01 PM
rhino99's Avatar
I am going to do this conversion too! I love the new yellow 400ex plastic. As close as the two chassis are in design, I would think that it should be a fairly easy thing to do. Just maybe a couple new mounting brackets.
If you find out anything, let us know
Old Jun 29, 2000 | 11:07 PM
JD250R's Avatar
Everything should fit. You'll need to make some supports for the side panels, drill new holes in the rear plastic for a 250r seat or use a 400ex seat and modify it. You'll need to cut off the front tabs on the 400ex seat on bolt a 250r braket on or flip the tabs around on the frame.
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
