how to set slides on keihins
Old Mar 9, 2004 | 09:57 AM
toysforlife's Avatar
Default how to set slides on keihins
stupid question here. when i install carbs on a banshee . how do i set the the slides. are they all the way down and then i sync and adjust throttle cable. or do you have to have them open to a certain position before setting adj? i have pj 34 keihins on a banshee. i was told by a friend to open throttle till my slides were all the way open and then sync my carb tops to that. any help would be great thanks
Old Mar 10, 2004 | 01:41 AM
aksledder's Avatar
ATV
customize
Gallery
My Page
profile
search
today
help
faq
home
logout
Everybody on this web page needs to call the peope at bender racing in new York or Aaen performance in Wisconson and order Aaens carb tuning book!!!!!!! Read and study this 1000 times and there will be less questions about the same old sh*t. This is a great book, the only way to learn is study study study............... Dude just make sure they open at the same time. Use your eye ***** and fingers. Also make sure they open all the way. With the thumb throttle pinned open, use your finger and try to push the throttle slid up. Use the adjustment on the carb caps to adjust the opening and closing of the slides. Use the adjust near the thumb throttle to adjust idle. Can not remember if those carbs have a adjustment scew on the side that lifts and lowers the slides. If so you have several ways to get it done right. But anyway call Aaen Performance and get that book, you will be using this information for the rest of your life........
toysforlife
erie, Michigan
Tue March 09, 2004 8:57 AM
Report this to a Moderator
Reply Quote Top Bottom Edit
You are in message post mode [ FORUMS : THREADS ]
Classified Ads | ATV Forum | ATV Connection Magazine | Contact Us
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Hack714
Sep 20, 2015 05:54 PM
toonces
Sep 5, 2015 01:14 PM
