Banshee reeds
Old Jul 23, 2000 | 02:42 PM
SBISHOP's Avatar
what kind of reeds do you run on your banshee?
Old Jul 23, 2000 | 02:58 PM
BansheeBill's Avatar
V-Force Delta 2.
Old Jul 25, 2000 | 07:51 PM
FMF's Avatar
FMF
V-Force Delta 2.
Old Jul 25, 2000 | 08:24 PM
MADPOWER's Avatar
carbon tech...
Old Jul 25, 2000 | 11:14 PM
fooshead's Avatar
Boysen Carbon Fiber Dual Stage Reeds Stock Cages
Brian 96 Banshee
Old Jul 26, 2000 | 01:50 PM
RoostKing's Avatar
Boyesen Dual stage/reed spacer. Stock cage...
RoostKing...
Old Jul 26, 2000 | 03:18 PM
sAyIt_fmf's Avatar
Unless You have porting, reed spacers or updated cages....I would stick with stock reeds..
Even though the banshee is a powerhouse...It has a relatively low amount of vaccuum in the reed area. After numerous tries/ attempts/ swaps etc. I have yet to see enough of an advantage gain with other than stock reeds. Especially if you plan on using the stock cages. Now it's a different story if you are running a rad or ram valve etc.
Old Jul 29, 2000 | 05:50 PM
LiveWire's Avatar
I have heard of people using epoxy to reduce the crankcase volume to get more vacuum.
Old Jul 31, 2000 | 12:57 PM
WyoRider's Avatar
Sayit, when I installed my Boyesen reeds I noticed a significant improvement in throttle response. I think it was a great investment.
Old Jul 31, 2000 | 02:31 PM
sAyIt_fmf's Avatar
I was just saying that I have not seen a big enough improvment anywhere to justify the cost of some of the aftermarket reeds.
For me...Just a matter of changing reeds did nothing....No noticable difference....But I never did have a problem with throttle response.
I guess all engines respond differently to mods. I know that when I went back to the stock reeds...thats where I saw the most improvement. If you talk to most performance shops...(as long as they are not hard up for cash) They should be able to explain why the banshee in stock form can have trouble with High tension reeds...
Glad things worked out for you.
