JETTING ?
Old May 13, 2004 | 04:48 PM
speeeedy's Avatar
Default JETTING ?
I know this a atv forum but you guys seem to know your stuff so here is the ?. my kid has a 03 suzuki rm 65 and we are going to put a amsoil foam filter and a pro circuit tip should the stock jetting be ok. I am not going to get a header pipe for it until his birthday will i need to jet it againor at all. any info is greatly apriaciated thanks.
Old May 13, 2004 | 09:26 PM
hondarider300's Avatar
Default JETTING ?
if u increase the air movment through the quad in anyway (air filter, pipe etc) then yes you will have to rejet, unless its only a little bit of air, but with a pipe its too much air for stock jetting so id say yes u will need to rejet it.
Old May 14, 2004 | 12:09 PM
speeeedy's Avatar
Default JETTING ?
Thanks hondarider300!
Old May 14, 2004 | 12:45 PM
speeeedy's Avatar
Default JETTING ?
I was told that with just a tip that u dont have to rejet and the amsoil air filter should not move any more air then stock. or does a p/c tip move to much more air on the 2 strokes
Old May 20, 2004 | 05:58 PM
Slacker1bob's Avatar
Default JETTING ?
Ill tell you what I tell everyone else. Check your plug and see if you NEED to rejet. If you dont know how to jet, find someone that does.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
