Aftermarket Reeds. Which is best and why?
Old Aug 6, 2000 | 06:10 PM
hondaron's Avatar
I tried boysen reeds in my 250R and after going through jetting hell found that low end was slightly better, but top end was not there at all(and i know how to jet a carb)It seemed like the reeds just wouldnt move fast enough in the top rpm,s. I took them out and through them across the yard as far as i could and went back stock. It ran great after that. Ill never put that crap in my motor again. I think all those reeds are mostly hype !!!
Old Aug 6, 2000 | 07:51 PM
b370's Avatar
if your looking for documentation as to what works and what does not.. try this link.
http://www.quadstore.com/sys-tmpl/scrapbook/
walter
88 Banshee370
95 Dodge Ram 4x4
99 Quadbuddy
Old Aug 6, 2000 | 08:54 PM
99Scram500's Avatar
boyesen suck, they actualy take away horsepower. the delta vforce do add a few horsies, so there the way to go.
Old Aug 7, 2000 | 01:21 AM
Xplor's Avatar
Which setting? I have mine on low setting. Would it be better on high? Any differences???
Old Aug 8, 2000 | 02:52 AM
  #15
GraydonBlaster's Avatar
I put Boyesen Pro-Series reeds in my '99 Blaster and could feel the difference. It made it climb better and also made it pick up the front wheels in higher gears. The dual stage design works like a four barrel by restricting the flow at low rpm, then opening up all the way at high rpm.
Old Aug 8, 2000 | 02:55 AM
  #16
I almost forgot Pro-Series reeds make it run richer than stock also.
Old Aug 11, 2000 | 07:47 PM
  #17
Backcountry's Avatar
Well, it's interesting. I've played around with a few different reeds, and at least in my set-up it seemed to like the Boyesen's the best.
Reeds won't make power, it can "move" it around a little.
I felt that with the Dual Stage it gave the best response between 3000 and 5500 RPM's. I have tried a stiffer CF reed from TDR and it seemed to provide the best top end power. Seemed to me, due to the stiffer reed, it didn't flutter around as bad at higher RPM's.
Carbon Tech. had a article out a while ago about CF reeds, and they or someone else had done some strobe photos of reeds at different RPM's, and everyone was suprised how misbehaven the reeds were.
You're right, at higher RPM's they don't seal. So reeds actually become an incumberance to the intake pulse. They take up space and get in the way of the intake pulse.
Marketing ploy, perhaps....but isn't that what most of have to do, take in what someone says, analyze what they claim, apply that against what we know and make our decision from there.
-->Veesh<--I would like to pick your brain though on why the Delta's work better in larger displacement engines...Always looking for good conversation...
fd24
Jan 16, 2019 08:59 AM
flyin-lowe
Dec 1, 2017 03:18 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
