banshee igniton HELP
is there a way to check the flywheel or cdi box.
the stator turns out good for continuity and the primary on a brand new coil is good but the secondary has nothing??? should it ??? how do u test it exactly ? Im taking it to a guy tomorrow to check it. there is no spark at all.
all the switches r good, coil is brand new. stator is good for continuity flywheel is rusted it looks like and i dont know how to check the cdi box.
any help would be appreciated.
The only test for the CDI is to put it on a known good machine and see if it runs. Also, if you have a friend with a banshee, just swap parts to see what makes yours run. Also check all the wires and connections. I would also disconnect the ignition switch and kill switch, that will totally eliminate these from the system.
eric
eric
Jul 7, 2015 11:00 PM
