installing new carrier
Old Aug 11, 2000 | 02:34 PM
evan99's Avatar
im trying to put a new axle carrier in 87 honda 250r the problem nothing wants to come off my axle like sprocket bracket, right hub and tire and old stripped axle nut i dont want to damage anything should i just get a new axle or what
Old Aug 11, 2000 | 05:23 PM
retro's Avatar
I assume you loosened the rear bolts on the swingarm and tried to take the axle nut off? Can you loosen up the axle nut enough to get the ring off of the axle? Try to spray a lot of liquid wrench on the nut, lightly tap it with a hammer, or try heating it up with a torch. The axle should slide out to the left(stator side).
The rear brake mount is tough to get off because there is a rubber O-ring that gets pinched when assembled. You need to replace the P-ring when reassembling. Put grease or never seize on all parts when putting back together.
ERIC
ReconBayou
Oct 31, 2022 05:37 PM
2many2ride
Sep 27, 2015 04:35 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
