PVL vs CDI
Old Oct 6, 2004 | 06:24 PM
pimp250r's Avatar
Default PVL vs CDI
What are the advantages and disadvantages of these two ignitions?
I heard the PVL is for hotter spark or something?
Old Oct 7, 2004 | 04:15 AM
DaBeechMan's Avatar
Default PVL vs CDI
depends on the stator and coil as to what kind of spark you get.
The pvl is a "set" ignition. Meaning the ignition curve never advances or retards at any time other then what the ignition plate is set at. That is the reason why it doesnt run a CDI.
A cdi based ignition is much more flexable, depending on what cdi/unit your using you can make custom curves, switch curves with a flip of a dip switch. Mainly the most adventageous feature of a CDI is if you run a big bore motor you can throw a low timing at initial startup to reduce or eliminate kick back (easier to start) and still have the ignition advance to make good upper rpm power.
Old Oct 7, 2004 | 10:49 AM
pimp250r's Avatar
Default PVL vs CDI
thanks beech
Old Oct 7, 2004 | 04:14 PM
DaBeechMan's Avatar
Default PVL vs CDI
anytime playa
Old Oct 8, 2004 | 11:48 PM
CWG's Avatar
CWG
Default PVL vs CDI
Originally posted by: DaBeechMan
anytime playa
[img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img] [img]i/expressions/face-icon-small-happy.gif[/img]
