250r problems plaese help!!
Old Sep 1, 2000 | 11:23 PM
chado250's Avatar
I have a '88 250r it has a 310 kit in it. I just recently rebuilt and bored it out. The reason for the rebuild was that it overheated and scufted because of a blown hose. But after the rebuild water was coming out of the weep hole under the pump. So I replaced all the bearings and seals in the pump. Then it started leaking out of the over flow, and I just thought it was too full but thought I would check anyways. So while I was riding back it ran out of power and blew white smoke and now has no compression. It does'nt even have 5 minutes of riding since I did the work. This has me very confused so any help would be great. Thanks , Chad E-mail chado2@earthlink.com
Old Sep 2, 2000 | 12:11 AM
chriscoll1's Avatar
Could be a blown head gasket or o-ring.Did you forget to install one of the 2 o-rings on the head?
Old Sep 2, 2000 | 01:55 AM
Dill's Avatar
sounds like you blew the o rings in the head
Old Sep 2, 2000 | 03:21 AM
chado250's Avatar
Chris, It still has the stock style head gasget not o rings, but I did replace them with exactley what was on there befor, when it ran fine. Do you know why it would constantly leak out of the radatior over flow aswell? I think this could be the cause of my problems. When the cap is off it seems to be flowing fine. I am in the process of tearing the cylinder down and will see the extent of the damage. Thanks for your help. Chad
Old Sep 2, 2000 | 03:45 PM
rsss396's Avatar
A blown head gasket will do the same thing that is happening to you. I would buy a new gasket and try Permatex copper spray-a-gasket on it before installing it
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Dustinyoungs
Jul 24, 2015 07:18 AM
hondarider1234
Jul 21, 2015 11:53 PM
CRamshaw777
Jul 18, 2015 05:46 PM
