Need profesional Advise on bike setup Please Help
Someone in the know please help. I would like tips for setting up a bike for fast rail riding. Still handle tight on turns. With enough suspension to jump a set of triples bike will not be raced strictly pleasure also on a swing arm why do most mx racers shorten ther swingarm ????And can a sway bar be used and still get full travel on suspension. How do they work. Also i ride a quadzilla that has around 60 hp I love the power I want to build a bike this winter and all tips would be great i am thinking of a lonestar frame and go from there based on your advise..
A short swing arm, 1 puts more weight to the rear end resulting in better traction. 2 shorter wheel base = quicker around turns, better center ballance for jumping. A sway bar will effect you travel. they are for bikes set up to race on flat ground with tight turns= not good for jumping or trail riding. my advive on a lonestrar roller would be a xr650 4-stroke motor. you cant go wrong. Its one of the fastest -4 stroke motors and is very reliable and dependent. This motor wins the baja's all the time. I dont know the hp out pu though. fast trail riding and triples I would go +2 on the arms and resavor shocks, tcs, pep, works, elka ect. rework the stock rear.
oliveiracarlos
19
11-11-2015 06:49 AM
