K&N vs Uni
Old Dec 18, 2004 | 02:46 PM
Brambles's Avatar
Default K&N vs Uni
I talked to Lonn at Thunder products and he stated that the K&N and the UNI filter have the exact same flow. He has a flow bench and he says he uses all unifilters because with K&N your paying for all their advertising.
Old Dec 18, 2004 | 05:44 PM
86LT250RFatty's Avatar
Default K&N vs Uni
I agree. you cant read a magazine with out seeing 10 advertisements for them. On my old LT, i had a uni and switched to a K&N and i notice no differnce, didnt efect jeting at all. so i sticked with the uni because i felt more secure with all that protecting my motor from dirt.
Old Dec 18, 2004 | 10:35 PM
ZillaRider87's Avatar
Default K&N vs Uni
i use a UNI, and i run with no lid so i def need the best protection.
Old Dec 19, 2004 | 06:12 AM
pendejo's Avatar
Default K&N vs Uni
I've also used both, and they are both wayyyy better than stock, however for where I rode, I liked the uni a lil better.
i use gas to clean,and foam oil on it (messy,use latex gloves) just my not so humble opinion good luck
You do know that eventually the gas is going to eat away the foam and little foam particles will end up in your cylinder.
Old Dec 19, 2004 | 11:28 PM
  #15
86250rrider's Avatar
Default K&N vs Uni
yes i do.i replace every two years . those micro particles wont hurt anything any way.also the gas breaks down the glue holding rubber to the filter itself.i also run an open airbox with an outerware,only once did i have a problem hatfield mccoy rainy sob almost fouled a plug. my jetting must be good never fouled a plug in the r ..
Old Dec 23, 2004 | 06:05 PM
  #16
YamahaAtvFreak's Avatar
Default K&N vs Uni
Search it
Old Dec 24, 2004 | 02:11 PM
  #17
Default K&N vs Uni
search what?[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Dec 24, 2004 | 03:33 PM
  #18
Default K&N vs Uni
K&N vs.Uni...?
Old Dec 24, 2004 | 09:33 PM
  #19
MNWolverine01's Avatar
Default K&N vs Uni
Thanks for all the info guys. The Uni is on order.
Ryan
Old Dec 24, 2004 | 11:16 PM
  #20
Default K&N vs Uni
Originally posted by: YamahaAtvFreak
Search it
just another point less post.... but if in dusty conditions i would get a foam, for cleaner conditons, K&N....oh, foam is like 35$ cheeper too!
