mojave w/cr500 engine
Old May 16, 2005 | 11:45 PM
  #21
fordblaster's Avatar
Default mojave w/cr500 engine
why don't somebody host those pics and put them on this thread, so others don't have to wait to see them. i am currently putting an xr500 into a blaster frame, i had to do a lot of work to make it fit and that part is about to be finished.i got pics in the thread called, you think an xr500 will fit into a blaster frame with some cutting. check it out. yeah it probably will look sort of ugly but if it goes fast and beats yfz450's and z400 and such, it's great.
Old May 17, 2005 | 01:04 AM
  #22
NEWDUCK's Avatar
My dad used to have a xr 500 motor that had some aggresive cams that would smoke kx 250s so you could get your motor to run good with just a high comp piston and a cam or two
Old May 17, 2005 | 04:48 AM
  #23
Quadzillaboy's Avatar
Old May 17, 2005 | 07:30 AM
  #24
yeah, i wanna put a white brothers or hotcam in it, bigger carb but not sure how much.(it has dual carbs because it is a RFVC engine with 4 valves), i already got a D&D racing muffler and midpipe for 50 bucks. i will do some porting as well. it should run pretty good. all that things needs is paint and new plastic, i don't think it's ugly. mine is worse, i wish i could just fit the xr500 into the blaster frame without having to raise the top 4 inches. i am still working on the design.
Old May 17, 2005 | 10:55 AM
  #25
Duneaddict's Avatar
YEAHRIGHT!
Old May 17, 2005 | 09:37 PM
  #26
mojavecan's Avatar
thanks but i want to have it done better than that with custom made +4+1 a-arm and a a home gaz tank in aluminum. Today i put som nerf that destroy last summer, somebody fix them for me and install them on my atv.
Old May 17, 2005 | 11:00 PM
  #27
homdaddy's Avatar
hey mojo
now that you have it done what are you running for jetting
Old May 18, 2005 | 08:07 PM
  #28
speedi's Avatar
Quadzillaboy thats probably one of the coolest "beginner" quads i've ever seen i hope some day i can do the same thing so that some unfortunate soul asks me to ride it and then they proceed to fill thier pants. that will be the day
Old May 19, 2005 | 12:47 PM
  #29
Hello,
Did you mean my pictures from my quadzilla or the pictures that i posted from the mojave?
I think the mojave vibrates terrible because where the engine is mounted on the frame it is to long.
You must make it as short as possible. Take a look at the http://www.janssenmotorsports.com/.
They make a trx250r with a cr500 engine and make the engine direct to the frame as you can see on the pictures
Old May 19, 2005 | 10:11 PM
  #30
mojavecan's Avatar
i don't know about the jetting. i don't have the stock carb and it is a bite too rich.
